Windshield washer failure
Acknud
Morganfield, Ky
I got a replacement tank and pump from Tom's. I connected the red wire to my washer wire on my centech harness and the ground wire to the wheel well. No go. I don't here it running and it doesn't pump. Did I miss something somewhere?
Blue Bastard
Simple sh*t first right. After fighting problem I some time over look the obvious.
Example. Assuming you were going to test it by the wire marked washer and assume it would turn it on.
Good luck, I will not make any more suggestions or diagnosis other then what was just posted above about testing the pump and ground by jumping to the battery post.
904Bronco
San Martin, CA
Are you pressing the washer switch ?
In his defense...
Members here in answering questions deal with many different levels of competence and incompetence... Always start simple and work your way up
As seen on the car builder shows... It won't start? Did anyone put fuel in the tank? %)
Congrats on resolving your minor problem.
Acknud
Acknud
Morganfield, Ky
I guess I just assumed that if you have a classic Bronco and worked on it regularly the you would have to at least be marginally competent. ( I know what they say about assuming!) Now if I can just figure out my brake lights and front flashers!%)
