Windshield wiper fluid question..
Tram
My pump, tank, etc are all gone. I'm contemplating replacing it, but I was curious, is the wiper switch wired from the factory to operate the pump as well?
Seems like it can be pushed in. Thought this might to activate the pump?
half cab
Guru Bronco
Older Ford pu's from late 60's throu mid 70's have the same tank n pump if you wanted to look i a salvage yard.
Slednut10
Guru? That's funny!
X3. Tucks in perfect on drivers side.
Gweiner
Charlotte
subscribed. Do you simply change the pigtail and plug it in to the opriginal wiring harness or is there more involved. My original washer pump does not seem to work and I am interested in replacing it.
turbotim2
____________
It looks the same. I had to drill one hole for a bolt and used one existing to mount it. It fit right in there perfectly like the pics the others have posted.
Slednut10
Guru? That's funny!
Is the reservoir from Amazon the same as the ones that WH and other sell? Any modifications needed to make it fit?
My 76 had the extra brace from the radiator support to the wheelwell that needed to come out to fit mine. Others here have said it will fit with the brace but my clearance was 1/2 inch short.
