I've purchased a Ron Francis EFI harness for my '75 with a trick flow intake, MSD ignition, and an American Autowire "early bronco update" harness fromn Wild Horses. I've got it all hooked up, but I'm not getting spark. I think the issue is with a couple of connections. Namely, the Ron Francis harness has a three prong plug that contains an "ignition run" along with a temp sensor lead and an oil pressure sensor lead that powers all the relays and sensors in the harness on the drivers side, and the AA harness has an ignition feed on the passenger side that's intended to go to the positive side of the coil. The AA ignition feed is pink and has power. I was told by Ron Francis to splice these two together and use the power for the coil on the Ron Francis harness to connect to the coil. I've done it, and the engine harness does have power at the red wire on the coil...but I still get no spark. Anybody got any clues? Advise?
