Well first off, leave out the new regulator. Your alternator is a self-exciting, internally regulated alternator. Which means it's already got the regulator inside so you don't need an external one, or it's wiring.
You will still need (if you don't already have it) a new charge cable for the alternator.
This is what we sell for that application:
WH High-Output Alternator Charge Cable
You can make your own or buy it pre-made. Either way you need the larger wire to handle the current capabilities of the new alternator, and will no longer use any of the wiring that's currently on the back of your old alternator, or up at the regulator.
Starter uses less current than the old style, but it still never hurts to overkill starter and battery cables. So if your old ones are large and in good condition, by all means continue to use them. If they're older, or smaller, or looking a little worse for the wear, replace them with some good heavy cables. Minimum 4 gauge, with 2ga even more desirable for it's bit of overkill effect.
Wiring the starter is pretty straightforward. Instructions in the box, and many threads about it here.
What's the part number on your Summit HEI distributor? If it's a real HEI, meaning it's got the big GM cap on it, then you don't need your MSD coil (unless it's a replacement for an HEI?).
As for the MSD-6 module, I'm not sure how to add one to the HEI style distributors. It can be done of course, but is likely more trouble than it's worth and your spark is going to be much improved over normal setups anyway.
So depending on just what you have, a couple of those items sound like they're going to be unneeded extras for the time being.
