Outshine2
Went to drive the Bronco home from work this afternoon and it's having problems. It idles very poorly (though doesn't die on idle) and hesitates 1-2 seconds after pushing the throttle before responding.<br><br>After it climbs over around 1K it revs just fine. I drove it home and about 3 miles into the drive I was going about 55 and it slowly sputtered out and died. Pulled off to the side of the road and tried to crank it over and it wouldn't start till about the 5th try... usually it starts on the 1st.<br><br>It doesn't seem like a fuel problem to me but I'm going to go and check the output at the carb. I checked and plugs/wires/cap/rotor look fine so far. <br><br>It drove perfectly about 8 hours ago when I went to woork....<br><br>Anything else I should check?
