Took the bronco to Cruise Night last night and did fine. (New Painless harness in earlier this year, new FiTech too) Went to leave and nothing - zero from the starter. Key on primes up FiTech, good lights, etc. So I play around with C4 column shifter thinking its neutral safety switch issue, even check connections underneath, still nothing. Decide to jumper batt to S connection on solenoid with key on - she starts right up. Get home and still the same thing.
Check out some things this morning and decide it must be solenoid, get a new BWD starter solenoid from CARQUEST and still same issue.
So I try to jumper neutral safety switch on Painless harness- this where it gets scary. Bronco has push button starter with key as well, hopefully theft deterrent.
I disconnect Painless connection to C4 neutral safety switch, there are 4 wires, #919 with 2 male to female connectors so I figured plugging them together would do the trick - NO I got a runaway starter upon key on! key off didn't stop it either! Disconnected the harness and it finally stopped cranking, little scary there. So I calm down and figure ok I will just jumper the 2 #919 wires together and bypass the neutral safety switch that way, key on and same scenario!
I am stumped. Left the neutral safety unplugged for now. Checked the ignition connections and look good, checked the pushbutton starter button and even jumpered it, nothing
