Hi,
I am looking for a flexible Lokar dipstick. (Dipstick only required. Flexible housing not needed.)
The previous owner installed a Milodon set-up. He did a custom install into the oil pan. The Milodon setup uses a semi-rigid rod that gets hung up on the fitting that was used at the pan. With a little finessing, the dipstick will fit into the pan.
I would like to use the flexible cable that I have on a Lokar dipstick. I would need to have it semi-permanently attached to the Milodon billet knob in order to keep the setup at the oil pan. I prefer to not mess around with the fitting at the oil pan for fear that it might turn into more of a project.
If anyone has a Lokar cable laying around (and it's the right length), I'd like to talk to you about buying it.
Jeff
Jeff
