YA-159 Fan?
Oatmeal
Hi all,
Came across a NOS Motorcraft 7 blade, 7 1/2" factory flex fan D6DZ-8600-D on eBay.
Says it's for a 6cyl Granada.
Looking at the photos, it looks exactly like the Bronco 7 blade fan.
Very aggressive blade angle, looks like it would move some air.
Is this possibly the same fan with a newer part number?
Trying to keep my 351W cool.
Have a decent size Griffin alum radiator and a Derale six blade 18" rigid fan but,it gets pretty hot after extended idling.
Hans
rguest3
What do you consider "Pretty Hot"?
Is the current 18" fan a Flex Fan or a Rigid Fan? A 18" rigid fan should move plenty of air.
What thermostat do you have installed? Fan shroud installed? Good water pump?
All of these parts to the Cooling System need to be installed and up to par.
O
Oatmeal
If you read the entire post it says: "Derale 18" 6 blade rigid fan"
Not asking for advice on how to cool my Bronco, want to know if the fan in question could be the same fan as the OEM Bronco 7 blade fan.
The description refers to it as being 17 1/2" diameter, is the Bronco fan an actual 18"?...the seller measured it "tip to tip"
And no, the fan I have doesn't move a whole lot of air at low speed, where I need it the most.
Hans
O
Oatmeal
Been doing a little digging.
Saw on a Ford truck BB that a guy is using that fan to cool his V8 68' F100 successfully and a V8 swapped Ranger in the hot Texas heat.
Should work well in my Bronco, then.
Found another site that has a bunch of them for a better price:
D6DZ8600D - NOS Parts
https://nospartsltd.com/product/d6dz8600d/
I ordered one.
Hans
PNW
Well Oatmeal, when you include THIS with your question about fans you obviously have an issue cooling your Bronco.
"Trying to keep my 351W cool.
Have a decent size Griffin alum radiator and a Derale six blade 18" rigid fan but,it gets pretty hot after extended idling."
Someone tried to help.
O
Oatmeal
Look,
Not trying to start an argument and I apologize if I got under someone's skin.
I've owned this thing for over 35 yrs and had a few different motors and trannys in it over the years (went from a C4 to an NP435).
Never actually overheats (boils over) but, will get hot enough that you can burn your hand raising the hood after prolonged idle.
My after market temp gauge will read 220* after a while but, will cool down when driving down the road.
Maybe the gauge isn't accurate but, my infrared temp gun will confirm it at the coolant outlet neck.
Maybe I should have wrote trying to keep my 351W "cooler"......runs warmer than I like.
Anyway, my question was about the fan.
Hans
PNW
No idea on the fan. I would have to be able to see if the blades are actually flexible or like all the 7 blade OE fans I've seen and used on Broncos and I can't with those pics in the ad.
The actual stock OE fan pulls a ton of air. Is your pic showing the stock one used on Broncos? That I don't know.
Since if it isnt cooling properly at low speed & rpm then improving air flow is heading in the right direction.
Typically the problem and trying a different fan that would pull more air at idle would be the fix but making sure ALL the other contributors to inadequate cooling are addressed also... mainly shroud, air flow, wtrpump, etc. Do you have a good shroud?
O
Oatmeal
Yes,
OEM shroud in place (Remember K bar S), 190* stat and stock pump.
Just got it out of moth balls, been sitting for almost 5 yrs.
Going to do a complete flush and replace the stat just for peace of mind.
Always ran warm at low speed, think I just chose the wrong fan.....just doesn't move a lot of air at idle.
Used to run a Hayden 7 blade with my old (healthy) 302 and C4 (big cooler) and never had a problem.
Tried finding a Flex a lite or Hayden 7 blade and everybody seems to be out of stock and Tom's repro is kinda pricey at a $100
Gonna give it a try.
Hans
PNW
Good shroud fit is beyond important.
$100 is well spent money on an OE type fan design when you can't cool enough.
Another clue on your post is itsbeen sitting for a long time. Most people dont understand the insulation properties of rust on the insdie of a block. Acts lile excellent insulation and therefore greatly restricts heat transfer.
Acid clean the block is usually a necessity on an engine that's been sitting. This allows good heat transfer between the cast and the water. Heat transfer is critical.
Spend the coin on a well designed fan. OE outperforms almost everything that is aftermarket.
Dirt on each and every cooling fin, scale and gunk insulate on every tube on your radiator and rust film in your block are awfully dang good insulators and restrict heat transfer.
You might know all this already but many dont understand efficiency and thermal conduction well.
Good luck, buy the best fan you can. TBP has an OE fan that pulls a ton of air.
Pops68
Bronco Rookie
Bazetta Township
I have a 7 blade fan that came with my Bronco......is there a number stamped on it somewhere to tell if it is the one you might need? No longer have the Bronco, just a few odds-n-ends that I haven't gotten around to selling. I can get a picture for you if I know where to look for a number/stamp.
Pops
jckkys
When looking closely at the ebey example, it looks very close to the OE fan. It's a couple years newer design so it has double thickness leading edge on each blade but otherwise is the same. It's a good price and new. It is a flexible blade like the OE '66-'77 Bronco fan. I haven't found a better design. It moves a ton of air and is very quiet.
JB Fab
220* IMHO is just starting to get hot... not panic hot
