[quote author=NoAZ68 link=board=5;threadid=16266;start=0#msg124026 date=1050171332]
Thanks for the reply.
He actually wants $150 for it and states that he is only selling it as a core. I figured for that price it almost couldn't hurt to check it out. Do you lnow in the long run, which is the must trouble free, cheapest, and easiest option (ZF or AOD) and how new of a valve body and pump do I need?
Thanks...
[/quote]
ZF will probabyl be the most rouble free. The early AODs had a number of issues that you might want to avoid. If you want a non- computer contrlled OD auto, then go with the GM 700R4. They can be built stronger and cheaper, and has a better gear set ... oh yea one more thing on your AOD.. It will have the exact same gear set as you C4/C6 except for first and forth - first will likey be 2.40:1 (from 2.64:1 from C4, and 3.06:1 for the 700R4) but with a .67 OD.
If, big if, if it has the wide gear set, go for it, other than that, dont mess with it.... it take too much $ to build right.
$100 for a core is an incredible deal. Im looking around LKQ and BestCore Inc here in Hosuton, and I cant beat 350.
