engine Vin
2b1ask1
oklahoma
I was wondering how to determine if the engine in my bronco is original.. its a 73' with a 302...
NGABronco
N. GA now South Carolina
Hey 2b1, there is a casting # on the block just above or around the starter.
Ya' need to get that number and then start the search, I found that somewhere last week while I was trying to determine what I have in the 66'.
I think I googled "302 Ford Engines". ???:cool:
RH
there's a casting # on the bottom right rear of the block next to the pan, the first two letters will be D3.
Quick & Dirty
Ford didn't stamp a vin on the engines, so there is no way to tell if it is the original, or a replacement. There is no "numbers matching" like a GM.
The casting number will tell if it the right vintage, but may not give the exact year, just the design year of the last revision. A 73 block could have C8TE, D1TZ, or D1OE. There should be a casting date code above the design code, first number for year, letter for month, more numbers for day. If there is a decal on the valve cover that will also have the month and day of assembly.
SHX669
Like Quick and Dirty said ; once you remove a motor from a Ford it's difficult to tell what vehicle it came from .
You can Id the motor ;although sometimes not the exact version . And in some instances not the exact year it was built . Most of the time you can get within a couple of years.
SHX
Jonboy69
My 69 has the following info on the motor. Does this indicate anything or tell if it is correct for a 60 bronco ?
ENGINE TAG: (aluminum id TAG BEHIND COIL).
302 C 69 5
9-C K296-S
BLOCK CASTING ON DRIVER SIDE BEHIND TIMING COVER
9C12W
Quick & Dirty
302 C 69 5
9-C K296-S
Engine displacement, plant code, Model year, Change level(revision)
Model year-month(March) Engine code number
So it's a 69 302 assembled in March.
9C12W
1969, March 12 The stamped number there is the assembly date. Not sure of the last letter, could be assembly plant (Windsor?) The casting date is above the casting number behind the starter.
2b1ask1
2b1ask1
oklahoma
are you guys talking about the tag that is on the carb right behind the coil???
Jonboy69
The tag that is on the carb is I believe to id the carb. Autolite 2100, motorcraft 2150, etc. Not the motor. I have anold fairly stock 69 & I came across a tag behind the oroiginal coil. The other numbers thhat I referenced are on the driver side head in the front of the motor. Thanks quick & dirty. Sounds like I probably have the original motor. I contacted Ford fore a build sheet & they had no record with the vin I provided them. I am going to double check.
Steve83
VINs weren't standardized until 1981, and Ford doesn't have much documentation on them before ~'90. I got them to send a build sheet for my '83 VIN, but it was nothing more than a VIN decoding. No vehicle-specific info - they didn't even get the trim level right.
2b1ask1
2b1ask1
oklahoma
i looked at he plate that was on the carb, behind the coil and there was nothing on it...It was just kinda rust looking...
