Bronco SS 4 years and counting!
Revelation
Decided to add a new thread for the stretch run, as the other build thread is rather long, CLICK HERE TO SEE THAT THREAD.
As most of you know I have been working on my Bronco Chipper for the past 3 years with the help of my Uncle James who has been a Bronco Guru for as long as I can remember.
We did loose about 14 months after he was diagnosed with Cancer, But I am happy to say as of his last check-up he is cancer free.
The past month I have been hammering away on the body, last week the remaining body was sent off to the blaster, and was in etch Primer by weeks end.
This week has been replacing floors, firewall, bed, Ect. We chose to fabricate our own many months ago.
We had several 4x10 sheets of HT Stainless laying around and decided to use them.
The Cowl, firewall, floorpans, kick panels, and bed section are being replaced. We have chosen to leave the rear wheel wells stock as they were in good shape. The Stainless will be given a satin finish after installed, the wheel wells, and inner quarters will be bedlined. as well as any sheet metal on the underside. the stainless will not be covered, except in the areas where floormats would normally be used, in those areas I am going to use some aircraft wing walk paint.
Today I installed the first 5 panels, the bed section. We decided to use Stainless/Stainless Rivets to ease assembly, I know there will be the guys that are against this and would weld everything in. The rating for the rivets far exceed the stresses that will be exerted on the body.
Although I did not take a picture we installed not one but two cross braces under the bed section. The braces were also fabricated from the same material as the floor sections.
We did do some re-engineering of the bed section, extending it to where it will rest on top of the body support just behind the front seats. this will help strengthen the whole assembly.
It is alot of trim and fit to get everything in to our liking, as we all know our beloved Bronco's Spec's varied from Bronco to Bronco, but I feel the end product will be well worth it.
I will be posting more pictures as we install more.
Smokeater11
Auburndale,FL
Oh how sweet that is gonna be!!!! Chipper is definitely a "one off" rig from top to bottom. I can't wait to get a chance to look it over.
P.S. Your uncle looks like my kinda guy. I want one of those tractors!!!!!! GO GATORS!!!!!!!!
bax
Old Member
Rolling along. looking good. you know what we say. Git er done!!!!
Revelation
Revelation
Took half a day off today, went catfishing with my son, Great times, ever fought a 5 pound catfish on Ultralight tackle and 4lb test?
But I did complete the filler pieces in the bed, and posting a pic of the underside to show the cross braces we fabricated. And Picked up a new EZ harness. Things are rolling along at a rather fast pace.
( I know it looks like a gap, but that is just Sharpie Marker)
sprdv1
REBEL
You gotta have some free time too right.. Coming along great. VERY Glad your uncle is cancer free, that is awesome
Crewwzin
Freeport, Fl
Damn son...I know you said you had something special, but it didnt even cross my mind about all that stainless you showed me you had layin around. Lookin good bro, lookin good.
Revelation
Revelation
Now if I could talk Dennis Carpenter into stamping a few pieces, the whole thing would be stainless.
bosshoff
I did my floor pans using rivets as well. It worked well for me. Someone on my thread mentioned that if I were to use some of the SEM two-part epoxy body cement that you use the double tube gun to apply, that the installation would have been bullet proof.
Revelation
Revelation
I thought about that but since I am going topless, and it will all be stainless, as well as some design changes,( the 4 filler pieces are in at a slight angle to keep stuff from sitting in the corners) I thought it would be overkill. Besides the specs on the rivets we are using are not to shabby. 950lbs Shear and 1200lbs tensile. I beleive that is alot stronger than the factory spot welds. There are right at 150 of them used just for the bed section. We are going to use a marine seam sealer.
Revelation
Revelation
Got the front section of the bed cut and installed today, And I must say it is looking amazing. All that purty RUST FREE FOREVER SS in place knowing it will not have to be primed or painted sure makes it seem like the end is closing fast. Moving on the the floors, firewall, tunnel and cowl next. Fun times. Remember folks, Measure not once, not twice, but 3 times prior to making any cuts.
As a side note, I will be using an EZ 21 circuit harness, won it on EBay yesterday morning, payed with PayPal, and the Brown truck dropped it off today, Now that is fast shipping.
Revelation
Revelation
Swung by the shop to get a few pics of yesterdays progress, and dropped in the floorpans and tunnel to just see. What do you think?
Then it was off to a local car show.
Revelation
Revelation
Finished securing the Upper Seat panel and drilling the holes for the seatbelt bolts.
Tomorrow the Cowl, tunnel and firewall get started.
Revelation
Revelation
Attacked the tunnel and cowl today, got it all preped to start putting the new pieces in tomorrow. As most may know the cowl is a haven for rust, very poor design by Ford. when we pulled the cowl off we found what I think is not to bad, got it all cleaned up and rust free.
and with the new Stainless Cowl set in place, still goingot do some fitting but it is real close.
Since I will be going roadster, and a Mojave heater we decided to totally do away with the "Fresh Air" ducting and flatten out the cowl. The kick panels are also being replaced with Stainless.
More Pics tomorrow!
Revelation
Revelation
Hope to have the cowl, kick panels, and tunnel done, or close to it today, Pictures to follow.
Revelation
Revelation
Very productive day, And after today I can say without reservations that this tub is now 100% Rust Free, Every nook and cranny that Ford built into Broncos has been deconstructed, and made rust free either by Blasting or replacing with Stainless.
The channel under the cowl was cleared of all rust, heavily primed and readied for the cowl.
Then we attacked the kick panels, and Cowl Mounts.
We mocked up the drivers floors, just to see.
Then to finish off the day the first section of the tunnel was installed.
Decided to make a plate to mount the top part of the tunnel, just to give some adjustment if needed. All joints are sealed with Marine Sealer/Adhesive.
All in all it was a good productive day, Tomorrow, Complete tunnel, and start on the firewall/floors.
Revelation
Revelation
Had a productive day, getting the measurements right for the 435 shifter, Going to fab something to replace the half of the body brace I am going to have to cut.
Did I mention that the tunnel is a bitch?
Spent the better part of the day getting it to fit the way I want it, still not perfect but I think I have it where it needs to be and is going to stay. Had the floor pans and firewall sections in place and it is gonna be sharp!
No pics today, forgot to take the camera with me.
