Where to put a....
NYLES
Anybody got any great places to put a trans cooler W/fan? I've discovered nowhere to put a 10x12 cooler with a fan
help?
any thoughts on a tubular finned cooler?
Revelation
Between the pass. wheel well and the core support? Oh wait your batter is prob. there.
May have to move a few things around but could mount it flat on the top of the wheel well?
Scoop
Have Bronco, Will Travel
Cuchara, CO
Nyles, I mounted mine where Stoppe put them - horizontally under the radiator, between the frame rails. I then mounted a rear gas tank skid plate in the front to protect it. No pics of the cooler mounted but you can see the skid plate mounted in front. Cooler is mounted just above it. Cooler and fan fits in there great! And no taking up space under the hood.
NYLES
NYLES
well thats were the new EFI breather will be
NYLES
NYLES
that might work, esp if i ever build my bumpers I have though about a alum finned verisoin there also
BroncoJAK
I think we've decided to put Bubba's underneath bolted to the rear floor.
NYLES
NYLES
VW1.....What you know about em finned aluminum ones?
Buldozer
Bronco Virtuoso
God's Country
You can always get one of those like I got on the Harley....they say they are bullet proof. To demonstrate, they shoot them with buckshot up at Sturgis and they don't leak! They are tough as hell!
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Under the passenger seat works well if you attend to mounting and mud guarding. Derale on the '76.
NYLES
NYLES
whats the finned one cooling? or you got em both coolin?
MarsChariot
Planetary Offroader
The finned or rail type is for high speed with air circulating. When doing low speed crawling or driving in traffic, if the rail type can't keep up, the fan cooler cuts in and does the trick. So the fluid runs through the rail type first then exits into the fan type cooler for back up.
Viperwolf1
electron whisperer
That is a nice setup.
