ILikeBond
- Jan 27, 2009
- 908
Installed the WH 1" body lift today. Was 95% done, had only passenger side mid-rear mount left (the real annoying one). Covered the hole on the driver side with tape, setup went fine. Passenger side I intended to tape to prevent the nut from falling but didn't consider the sleeve, and when I inserted the bolt, it hit the sleeve into the hole.
:-X
:-X
I guess I can call Wild Horses and ask for a replacement, but I'd like to get this thing finished and also don't want that sleeve rattling around in my frame.
Any suggestions on fishing this thing out short of drilling the frame? The frame drops right after that hole, so it may have rolled down into the lowest part of the frame.
Right now I'm thinking of making a piece of particle board or similar slightly smaller than the frame in both dimensions, attaching a string to a wire, putting the wire through the frame till I have the string on the other side, then using the string to drag the particle board piece through the frame, kind of like a cow catcher. Would have to do it without it getting hung up on anything, bolts and such, could be tough.
