vtboy51
- Aug 26, 2016
- 389
This has happened about 4-5 times over the past year, I'll start the bronco and get 0 oil pressure on my stock gauge. For obvious reasons the first time I freaked out, thinking I had a major problems so I bought a mechanical gauge, installed it and had 50psi. After confirming this, I reinstalled the original oil pressure sending unit, restarted the bronco and the gauge now read correctly.... I'll also add, before swapping in the mechanical gauge I grounded the wire that connects to the sending unit and my gauge moved, which told me the gauge was good.
Like I said this has happened a few times and each time removing the sending unit and reinstalling it fixes it, but I'm not sure why. Does the sending unit need a good ground, which might be intermittent??
