I'm baffled right now. My '76 bronco is constantly "puking" water today. I "burped" the motor by letting it idle with the radiator cap off after filling it up with water yesterday.It ran fine yesterday put about 40-50 miles cruising around. Temp was between 180 and 190 the whole time.
I get in it today and decide to make the block; roughly one mile. I get into it a little, but too not much. Temp gauge pegs 230, overflow bottle is slam full and radiator is empty. Pull into a family friends house and fill up back up with water. Ease back to house and radiator empty again when I get back to the house and by the time I make it in it pegs 230 again. I run the water hose over the radiator to cool it down. Rinse and repeat a few times; still running hot and overflow reservoir still full.
302 with c4; motor and tranny rebuilt professionally. Motor bored over ~.25-30 something like that.
Mild Comp camshaft.
Stock radiator
Radiator hoses are not leaking.
Has a fan shroud.
New water pump and 190 thermostat.
Seems to only "pukes" when I get into the throttle. If i ease into it doesn't do it as much.
If I take the radiator cap off and give it heavy throttle under the hood from the carb it starts puking...
Bad thermostat? Sticking maybe?
Radiator Cap? it has 12-16lb cap
Radiator stopped up?
Transmission cooling?
Any ideas?
Mild Comp camshaft.
Stock radiator
Has a fan shroud.
Any ideas?
