Is it possible to remove the speedometer with out taking the whole dash off? I can see its held on by 4 screws on the dash but wasn't sure if there is a lot more to removing it on the back side.
Disconnect the speedo cable, remove the 4 screws in the dash, then carefully push back and down to expose the wires. Disconnect wiring and pull the bulb sockets out to remove unit.
I've had mine in and out SO many times. I've never had to remove anything other than the speed-o cable from the back of the cluster.
I just detach the speed-o cable, remove the 4 screws that hold the cluster and then push the cluster in and up with some wiggling and it comes right out the bottom.
I put a chair outside the door so I can lay down on my back. Sticky wire numbers on the wires and sharpie the numbers on the back of the cluster. Mine has been in and out so many times I can do a total swap in less than 30 minutes.
As others have stated, yes it can be done and not too hard. The metal rim around the glass is easy to scrap the pain off sliding it in and out from under the dash. If you care about it you may try protecting it with some blue tape.
While not necessary to access it, pulling the fresh air box make working on the back of the gauge much easier then crawling under the dash. Much easier once I found that trick.
