bteutsch
- Jan 11, 2009
- 873
So today I set out to make the brake warning light a little more useful. I found a switch on eBay that was designed to add a emergency brake warning light to old ford cars. The switch I found was for a galaxie. Since all the brake imbalance switch does is complete a ground, I got the idea to use this add on switch to do the same thing for the emergency brake (parking brake) and make the light still function for both uses. I forget the dang parking brake is on just about every time I use it.
Only had to mount the switch to the parking brake mechanism where it would make contact when it is depressed. And run a single wire to the proportioning valve harness.
