• Be EXTREMELY cautious if someone offers to buy your Bronco for more than your asking price and sight unseen. ESPECIALLY if the buyer is overseas. It's probably a scam.
    Discuss it more here:
    http://classicbroncos.com/forums/showthread.php?p=514932
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
TX 1971 Bronco
Status
Not open for further replies.
JohnnyB77
Amarillo, TX
1971 Ford Bronco
Lots of newparts and modifications.
Body..
***No RUST ,its been cut out and replaced with new metal.
I had it painted gray but it ended up not being the color I liked so I had it sprayed with flex blue dip. *
***Brand new gorilla fender flares from Wild Horses 4x4
***The front & rear *fenders are bobbed on the bottoms.
****Floors on inside have bed liner .
****Rock Ski Sliders w/Nerfs, Steel, 1/4" Thick From Tom's Bronco Parts .
***Front Pre-Runner Winch Bumper w/High Position Winch Mounting From Tom's , Has 2 Kc lights mounted and a brand new 9,000Lb winch.
***Rear custom bumper with built in receiver hitch.
**Best top Soft top also have a bikini top.
*Rock lights mounted on the frame.
***High output halogen head lights
Motor.
***Fuel injected 5.0 with lots of power .it motivates the bronco well .It was out of a 90's thunderbird. Had around 80,000 miles when installed .
***It has MDS ignition, Ford Racing Plug Wires .Runs great lots of power
***Ford Motorsports Headers *****************
***Flow-master exhaust
****K&N Filter and intake tube.
Trans..
****AOD Automatic Overdrive Trans with a B&M Shifter
****External trans Cooler with Electric fan also has a temp gauge inside the cab.
****AOD adapter from BC Broncos
****Twin Stick Dana 20 Transfercase
Axles...
***Full width axles out of a 1978 Bronco , high pinion Dana 44 and 9inch.
***Disc brakes front and back.
***5.13 gears, welded front and back.
***The 44 has the flat top knuckles off a 3/4 ton truck but made to work with the 1/2 ton brakes so you can still run the 15" wheel.
***Also the tie rod is 2" higher then the stock knuckles.
**Has custom coil mounts to bring the coil springs in so they are strait up and down..axles shafts are stock as far as I know but do have the solid spicer joints.
Suspension.
***Custom made extended radius arms . ***Wild horses Coil-springs up front probably 3" or 4'' over stock
***Custom built lower spring mount on the axle adds a bit of lift also
***Not sure of the brand of leaf springs on the back but match lift on the front no blocks.
***Rancho RS 9000 5 way adjustable shocks
***Body lift also 2-3
It sits 10 1/2 inches taller than my stock one measured at the headlights.
Interior..
***Custom built 6 point cage, not a kit. It is also tied to the frame for extra strength
***Custom high-back buckets up front with 5 point harnesses *****************
***Matching bench in the rear
with lap belts.
***All seats and belts are mounted to the Roll cage
***Dash has all the factory switches/knobs also has a bank of illuminated toggle switches that can be used for additional accessories.
***CB with external antenna
***Pioneer 2 way speakers mounted in the rear panels .
**Red Top Optima *Battery mounted in the rear with cut of switch ,more switches and a aux plug in the back also.
***Polished Tilt Steering Column and custom steering wheel from Toms Bronco Parts.
***Power steering via F150 box and extra large cooler
Brakes.
***4 wheel disc brakes with a brand new heavy duty corvette Master Cylinder
Tires.
Brand new tires & wheels less than 300 miles just now wore the stickers off
Nitto Terra Grappler LT315/75R16 = 35x12.50 R16
Wheels.
SERIES 7089 - FLAT BLACK ALLOY WHEELS
7089-6885
16x8 wheel size5x5-1/2 bolt pattern-0mm offset4.5" backspacing *The offset on these wheel put tire part way back under the flares.
Load lbs. 2200
Xtreme Alloys Powder-coated Black
**I had 37'' tires on it before I swapped axles, they cleared fine but the 15'' wheels would not clear the rear calipers.
**The bad. Its loud and fast .
It does leak a little oil from the valve covers probably needs new gaskets. Trans pan leaks a little from where the temp sensor is screwed in . It could use some weather stripping around the doors for winter time driving.
Additional info call 469 23O I982
ak68
off-road only?
Does the welded diffs mean off-road only? I would guess that might make for interesting driving on pavement :)
JohnnyB77
JohnnyB77
Amarillo, TX
diff
its not bad the tires chirp a little bit in a tight turn, other than that it has really good street manners . it tracks straight I can take my hand off the wheel at 70 and not worry about it jumping lanes.
ak68
Sounds good. This bronco will make a great rig for someone, that's for sure.
Jakedog
It sounds like you built a bad ass bronco. That one is tempting, but sounds a little too hardcore for what I'm wanting. Just curious, how does it do on fuel with the AOD? I know it's built for power, but with the EFI and the AOD, it sounds like it would be about the same or better than a carbureted 351 with a C4.
Also, how come the welded diffs? Sounds like you put a good amount of cash out for this rig. Why not air lockers. It sounds like a beast for off-roading!
Just curious
JohnnyB77
JohnnyB77
Amarillo, TX
Bronco
Honestly I've never kept track of the fuel mileage , I haven't driven
It much on the street since I finished it .
I don't have a hard top for it , bit I can pull it into my shop .
I think it's a standard height door I'll measure to make sure .
Status
