The float bowl vents are cast into the top cover. They could only be missing if the top cover is missing. The vent in the front above the center of the top cover does nothing. Again it's cast into the top cover but not drilled through on most 2150s. A few in the Cal. DSO had a 1/4" nipple. These may or may not have a hose to the charcoal canister. A cast in feature is hard to be missing. My '77 2150 had a vacuum cap on the nipple, to again make it irrelevant. Any needed parts that are actually missing, can be had through Walker herehttps://carburetion.walkerproducts.com/ford-motorcraft/ford-carburetor-kit-2bbl-2100/. They also have excellent rebuilding kits.
Rebuilding a 2100/2150 is very easy and the kit will have an exploded diagram will part names, and step by step instructions describing how to rebuild and set up your 2150. Classic vehicle ownership requires a fair share of the knowledge of how things work and a willingness to learn. The large scale rebuilders depend on customers who aren't willing to learn and instead look for shortcuts.
If you still want to pay someone else, try Champion Carburetor who was Pony Carburetor. They have both rebuilt 2150s and can rebuild yours, herehttps://championcarburetor.com/7578-motorcraft-2150-carburetor-2v-108-venturi-287-cfm-remanufactured-p-10732.html?zenid=a0e277f6ee90c6e9f39ab64567d0f131
