351 with explorer crank pulley/serp setup timing pointer
tasker
all knowing of nothing
NH
Have my project finally running....what are you all using for timing pointer? Had my Explorer damper done by Damper Dudes so it still has the trigger wheel but using Mustang injection and a TFI style distributor on my roller 351. Any insights as to what you've seen used for a pointer? Thanks in advance!
Interested to hear what others have done as well.
But it seems relatively simple enough to either make your own, or if you find one that will just bolt right on, do so, and then use timing tape to put the zero next to it when you are at TDC.
Not sure if there’s any place to bolt a normal factory style pointer to an Explorer timing cover, so you may end up making your own.
Z Bronco
I believe I have the Explorer timing pointer on my 351, Damper Dudes did the explorer damper on mine as well. I have the TFI style distributor.
You’re right. I keep thinking there is a round sight hole but now I remember there is a sensor thingy with an actual pointer tip on it.
Those should would work great.
I still say timing tape as your friend though.
tasker
tasker
NH
Just the pointer no sensor correct Warren?
SC74
That's what I did on my orange one ... just used a pointer off a mustang and it bolts on in place of the sensor that you are not using.
tasker
tasker
NH
COOL....Just have to dig through a few boxes to see if I have one!
Z Bronco
If I remember correctly, no sensor, just the pointer with its attaching hardware.
tasker
tasker
NH
DOES anyone recall what size bolts hold that pointer to the cover? Looks to me like they are designated just for that and not cover to block bolts....thanks in advance!
tasker
tasker
NH
WE be all set....have an Explorer one coming from Rock Auto....this way I know it works with the balancer
73azbronco
I think thread is sae but bolt head is a metric. Can't recall what.
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
I believe it’s 1/4-20 and they’re fairly short
