67BroncoBob
Newbie
- Sep 19, 2021
- 1
Hello, first time post. I have a 1967 Bronco with an Explorer 5.0 engine and MSD ignition. I've had starting and running problems since I got it. I have a brand new battery, I've tested the wires coming from the MSD box. While driving, the engine can just turn off and voltage drops from 14 to under 10. It will crank but not turn over. After I jump it it can drive for another 2 weekends 20-30 miles and then won't start again. Just last night it was running fine at 14 volts, I pulled the emergency light knob on accident and it cut out. Now when I turn the key it drops down about 2-3 volts every crank until it gets to 5 volts then does nothing. Any ideas moving forward? Thank you.
