Hmmm...that's kind of what I was thinking. Think I'll up it to 6 ga.
EDIT: Actually, since my main charge wire is 4 ga., should I match it?
Where is the battery grounded to now?
Hi, I think there is a ground lug area cast into the back of the alternator, near the bearing. Why not just loop that to the battery ground?
So, if you're going to use the same point of ground that the engineers did with the mounting bolt, I can't see a ground path improvement.The threaded boss on the block right behind the alternator.
The mounting bolt screws into the head, not the block.
