englewoodcowboy
Lick Creek Restorations
- Jul 25, 2010
- 4,200
I am looking for tips/tricks on the AOD swap from those of you who have retained the factory bell crank throttle linkage, how did you go about adding the TV cable? I have the Lokar kits but am wanting to retain the bell crank assembly if at all possible. I have the later assembly that does not have the engine mounted equalizer, it is a straight run from the bell crank to the throttle on the carb or in my case TBI EFI. I have not assembled it yet, just looking for anything else I need to obtain prior to hooking everything up as well as some pictures of what others have done.
Thanks for all the help!
