Was able to check the pulley alignment with
@nvrstuk ’s laser tool today and saw that I was still too far out, about the amount of my smaller spacer washer. I pulled the 3 smaller ones out and reinstalled with the single large and it is spot on perfect!
I could only run it for a few minutes but I heard nothing from the belt. If I hear anything else from here on, it would only be because my belt got stretched.
Thanks!!!
To recap, I know I went WAY out because my belt was coming off on the PS and unwanted it to stop. I spaced It out 0.215. I knew it was too much but being tmso far away I thought it would be fine and it did stay on no problem…but eventually started making noise.
Then I spaced to 0.178, it was good but incoild still hear a slight chirp. I continues to use the same belt as I wanted to make sure it was fixed before another band-aid.
Last and final spacing needed was only 0.107, which over that far of a span is nothing and I'm shocked my belt was coming off!
