- Feb 24, 2023
- 24
What is the best auto transmission that will fit a 351 Windsor? The bolt pattern on the 4r75 looks like it doesn’t fit. So which is the best transmission that fits this Windsor ???
General reference is "2-bolt starter" for the one you need. The Mod motor version is the "3-bolt starter".The problem is the bolt pattern on the bell housing of all the 4r70 transmissions are slightly off. What can I search or how can I specify the correct 4r70?
This is so helpful! I bought a 4r75 and it wouldn’t fit the plate as you can see in the pic. The plate fits the engine perfectly. Any Recs on where to find one that matches the bolt pattern on the plate?General reference is "2-bolt starter" for the one you need. The Mod motor version is the "3-bolt starter".
'96 to 01 Explorers are a good source. The 4.2 V6 F150 also has the same bolt pattern, just don't use the flexplate (wrong balance). The 4.2 is also the same as the 3.8 mustang version., down one clutch disk in one of the packs from the V8 version. All fixable with a rebuild. The Explorer and F150 are generally recommended as they are the only Windsor pattern and 4WD from the factory. They can be used as-is where a 2WD version will require a rebuild to add 4WD tailshaft (and multiple ways of doing that)
What pic?This is so helpful! I bought a 4r75 and it wouldn’t fit the plate as you can see in the pic. The plate fits the engine perfectly. Any Recs on where to find one that matches the bolt pattern on the plate?
The 6r needs an adapter since they only fit modular engines (thanks Ford for changing everything every couple yrs).My bad tech difficulties. I posted them here. But I can’t even forgive out the 4r70 how will the 6r80 match???
