So I already bought the wrong transmission but he’s gonna swap it out on Monday. The problem is up until now I couldn’t identify how to specify what I need. I’m gonna ask him to give me the 75 guts in the proper 70 housing. Do you think that will work? Do you have links to plate and adapters?The transmission has 3 starter mounting bolts. That transmission is for a modular motor.
That block plate you have is a 2-bolt starter, which matches the starter you have. And the windsor
It should not be a surprise that a transmission that has the wrong bolt pattern won't fit the engine.
At this point you need the correct transmission case. Listed the sources above, 5.0 v8 (pushrod) engines and 3.8 or 4.2 V6 engines. Those cases fit your engine perfect. Identifiable by the 2 starter mounting bolts.
Do NOT get a transmission from a modular engine. 4.6 or 5.4 will be like what you have. No V6 transmissions (except the before mentioned 3.8/4.2) either. Where to get one depends on what is available to you. Pick a part or other self service salvage yards, various online market places, Local transmission shop may have a good case they would sell (and maybe even put your 4R75W guts into). You might even find them at your local Ford dealer?
There are two speed sensors on the tranny i picked up, thats a big difference...FYI, they never made a 4R75W that will bolt to a small block. The 4R70W is the only one they made that will.
When Ford wanted to put the 4R70W behind the 5.4 they needed to beef it up slightly. Hardened planetary gears and a couple more PSI of line pressure were added, and to designate the changes the name was bumped from 70 to 75. Really nothing special, and the parts can be swapped by any competent transmission builder.
Did you end up with a 4r70 out of a F150 with 5.0, with 4x4???Now I have to pick the right headers, cats and exhaust. For me its all about sound. Any rec's?
I ended up with a 4r75 out of a 2006 f150 v6 2x4. Since I am having it fully rebuilt the guy rebuilding can make it a 4x4.Did you end up with a 4r70 out of a F150 with 5.0, with 4x4???
The 4r75 will NOT work behind the small block.. cancel the rebuild and get the 4r70wI ended up with a 4r75 out of a 2006 f150 v6 2x4. Since I am having it fully rebuilt the guy rebuilding can make it a 4x4.
Any headers, cats, exhaust and X back piping recommendations?
That transmission will work. But it isn't a 75, it is just a 70. The 75 was only used behind the 5.4 V8I ended up with a 4r75 out of a 2006 f150 v6 2x4. Since I am having it fully rebuilt the guy rebuilding can make it a 4x4.
4r70 out of a 98 or new and explorer or mountaineer will bolt up just fine. That is what I am running. Just need the controller.The problem is the bolt pattern on the bell housing of all the 4r70 transmissions are slightly off. What can I search or how can I specify the correct 4r70?
