Best options for leveling
powers4680
My Bronco has a little bit of a squat. Checking on best options to level it.
Shimmy
1977 Bronco
Maple Valley
if you don't mind lifting the rear you could add a block. looks pretty level to me tho
68Rcodeman
From the looks you are pretty close and a block would be to much. Maybe an extra leaf would pick it up enough and then it would add to your rear weight carrying ability. Simple to do. You will need a bottom leaf and a new center pin bolt that goes through all the leaf's and the round head locates in the perch. Hope this helps. Nice looking rig.
gnsteam
Lincoln NE
After adding the lift, have you checked your rear drive shaft pinion angle. If the angle could use some improvement. You could use some pinion angle correction shims. The shims would also add a little more lift and help the drive line.
jamesroney
Fremont, CA
Everything that @gnsteam said...except if you need pinion correction, (and they all do...) then go ahead and burn off the old axle perches, and install the newer, taller ones. Weld them in place at the correct pinion angle. The extra long ones from Wild horses work well too.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
How many miles on springs?
If new, give them a couple hundred miles to settle before deciding on how much more lift you want. The front may settle more than the back.
BGBronco
N A S H V I L L E
Tennessee
Interesting. It's usually the opposite of your issue. Are front/rear from the same vendor?
