Fiberglass is easy to work on. You can get kits for small stuff at the hardware store. The resin won't stick to plastic, so use plastic sheets, bags, whatever to your advantage over wood or something to clamp stuff together while the resin dries. Put new sheets on the backside of the breaks, and then use a softer, sandable filler on the paint side that's easy to work with.
Sent from my SM-S916U using Tapatalk
