- Nov 3, 2003
- 47,654
The switch should still be available I believe. It’s the two wire Ford version.
The single wire GM version is more common in the aftermarket, but the two wire is needed, if you are keeping the stock wire.
Actually, it’s not critical that you keep it for that reason only. The main reason is that the two don’t have the same threads and are not compatible with each other.
