    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
LA Bronco buggy, 4 seat, one tons, 4 link rear. 18’trailer, 408 ci
Status
Not open for further replies.
74dave
'Early Bronco Buggy 4 seat, 116” wheelbase. One ride weekend since build. Frame and tub cut, custom cage,back half built, front narrowed, one of a kind custom build. New front fenders, flares, new sheetmetal skins on the rear. Powered by propane.
Crawl ratio 66.1
Front axle: 78/79 HP ford dana 60, disc brake,drive flanges, 5.38 gears with grizzly locker, chromoly axles, stage 8 spindle nut,
Rear Axle: 14 bolt, tmr shave kit, pinion guard, 5.38 gears with spool, retubed, disc brake.
351 W, fresh rebuild, headers, 2 into 1 exhaust, HEI distributor, heavy duty motor mounts.
C-4 trans, deep pan., 1800 stall, remote trans cooler.
Atlas 5.0
Skid plates from oil pan to t-case
42” sticky red labels bfg’s with aluminum 20 “ beadlocks
PSC steering
Corbeau seats and harnesses
5” coils up front, duff arms, rancho rs 9000 shocks, limit straps, bump stops, rear has 16” fox coilovers and 4 link,
9500 lb winch with rope.
spare parts: propane tanks, rear axles shafts, starter, 2 rancho 5000 shocks, hei distributor with wires and new wire kit.
included 18’ trailer with 3500 k axles, drive on fenders, good tires, tool box, tie down straps, spare tire,
Included : small block ford stroker 408 ci built for propane. Originally mid 90’s roller 351. No problems when removed (different crawler) oil pressure stable, 192 thermostat, no smoke.
185 cc Trick flow heads with 2.02 intake, 160 exhaust, roller tip rockers, aluminum valve covers, edelbrock air gap intake, howards cam, dui ignition, remote oil cooler.
Motor has sat on an engine stand for the last 2 years, preserved, meaning cylinders were sprayed with lubricant, all opening sealed
The bronco will be available at OCBR for inspection, questions etc.
For Photos, l questions email dbwnola@hotmail.com
Total money invested in bronco build over 45k.
408 when new was over 8k.
trailer approx value is 2000$.
40k for everything listed, can negotiate delivery options, no trades.
74dave
Open to offers on bronco.
will sell motor separately.
Status
