Ok guys here is the situation, I had my D20 rebuilt and then I was checking it out on the bench when I got it back. Now I can not get the front rail to lock into 4 high. The rear goes into low and high and the front will go into low but not high. When I try and move the front rail into high it just stops and the shift rail will not ingage the gear into high. I am installing a nv3550 and I did not have the spud shaft at the time and I thought maybe with the bearing and the gear not installed that it was the problem. I recently got the new spud and it is all installed in the D20 and it still does not work. None of the insides have been removed, pills are still intact but I did seperate the rails to install a twin stick. NOW the freaky part, if I loosen the plug that hold the spring and the detent ball in on the front rail about half way out the rail shifts fine. And high and low work. As soon as I tighten the plug it binds up and will not go into high.
I did check to make sure the right spring is in the right side. The front rail gets the washer and the longer spring per the book. What would make the rail bind up and what should I do. It did lock in before the rebuild but with the stock T shift and it was real hard like usal. Thanks 69sport
