- Apr 19, 2013
- 337
Need some help before I order a complete rear end. 1967 stock bronco small bearing rear end currently. Engine will be a 347/351 mated to a 4R70W. I have the trans already, just trying to decide to have a local place rebuild or buy another already rebuilt from a vendor such as blueprint. Based on the gear calculator, 4.56 would be the best ratio for me as this will see mostly on-road driving, my wife will be the primary driver. She loves powerful engines, and burning rubber but I want it to drive nicely around town/highway, so overdrive is necessary.
My plan is to order this setup from Currie, I tried 3 places and they are the only ones who reached back out to me with any answers. Here is what I plan to order, and I was hoping if there is something I am overlooking or doing incorrectly, now is the time to fix it. So far, the only difference I can see about this complete setup from Currie is the location of the vent. I will have to customize my rear hard lines and not be able to use stock ones. Everything else looks to be the same as stock as far as fitting on the bronco. I am going with Currie's 11" drum brakes, no disc in rear.
31 spline axles
4.56 gear ratio
Eaton Truetrac
1310 Yoke (I believe this is stock size)
11 inch drum brakes
1/2 pressed in studs
5x5.5 bolt pattern
Torino ends (only option)
Currie said that the shock mounts are all in the stock location and it should just drop right in without modification. Just want to make sure I don't overlook anything since now is the time to buy what works best in this situation. I also asked Currie about a Dana 44 complete axle, more inline with stock configuration, I don't need anything built as strong as the current one they offer for our broncos. They don't build one like that unfortunately, probably not enough demand.
Any advice or criticism is welcome, I am not 100% set on Currie, but besides price, I don't see any reason to be worried about ordering from them.
31 spline axles
4.56 gear ratio
Eaton Truetrac
11 inch drum brakes
5x5.5 bolt pattern
