[quote author=lobo link=board=5;threadid=17370;start=0#msg132780 date=1052793434]
it seems like the air is nottraveling corectly on al or old tanks anyone have any idea how to mod the filler neck so the tank breaths properly and lets the gas in. simple physics tells you why it is happening but I don't know the gas tank good enough to engineer a solution! any ideas?
or does anyone have an exploeded view of it so I can check it out?
[/quote]
Your right. Simple physics. If you can't get the air out, you can't get the fuel in. I may be wrong but I'm guessing if you're having this problem, you probably have to run a vented gas cap. The only problem is that when you are filling up, you're plugging your vent with a fuel nozzle. The only real cure probably would be to install some sort of vent on the top of the tank. The orginal evap system handled this function but most EB's no longer have this stuff. I know mine doesn't. Just my .02.
