clinem03
- Sep 9, 2017
- 400
I have read some of the past threads on this issue, and know it can be the most frustrating one. I'm hoping that since I only have a small miss-alignment someone here can help point me in the right direction before I start trying to realign the driver door. When I got the truck back from paint, the door was aligned perfectly when the door was shut BUT the latch on the door was not aligned with the striker on the inner panel so you had to slam the door to get it to latch. I also have new gaskets and know that is at play here - but I looked at it when closing it and it was way off, the door latch was about a half inch above the center point of the striker. Even when you opened the door, it would almost 'pop' down before swinging out. I moved the inner striker around to get it better aligned but now the door sticks out a bit. I can live with it if its the best it will get, but it could be aligned a bit better to get the door to align with the rear quarter panel. Any ideas on what I should tweak to get the door panel to align better with the rear quarter?
In case it is helpful - I put on new hinges when we painted the truck and all the metal is original ford metal from the doors to the quarter panels.
