DeepC73
- Dec 25, 2020
- 217
I'm back at the door alignment again. I bought a set of new hinges, which helped quite a bit. As you can see from the pics, I'm very close. The front fender is loose, so don't mind the front line. I can line that up when I'm done. My issue is the 1/2” gap at the rear bottom corner. I have tried almost everything for days. Tonight I realized that the door is all the way against the door weather stripping. I even removed the weather stripping, but it didn't make any difference. As much as I hate to say it, I think the passenger door is too wide. Is this common? Am I missing something? Any help is appreciated.
https://share.icloud.com/photos/0lh6ICowZjIT-H_aTtowPKDFg
