Rhoward104
Hello and thanks for any help.
When considering an fuel injection upgrade I did not see the posts about using a explorer serpentine configuration. I found a 1988 thunderbird with low miles and have purchased removed and installed in my 1973 bronco. I removed entire wiring harness to install computer and whatnot in the bronco.
Problem is that not the air compressor mount is hitting hood and clearance between water pump and radiator is too close to install fan.
If I purchase an explorer serpentine set up will this take care of my problems and also where can I install and what kind to purchase for the air condition condenser (radiator)?
Also if I purchase an explorer to get parts should I use computer from explorer or thunderbird or does it matter and is there a better option for controlling engine?
Respectfully and thanks!!
