- Joined
- Aug 23, 2007
- Messages
- 24,325
Thanks Gary. I was trying to figure out what I needed to do to get the evap hooked up. I didn't have much luck finding a wiring diagram. I might just swap the pins.
I'm going to start you all off with a little video. It covers the very basics of a harness re-work. I'll add a full write up here with pictures covering pin numbers, wire colors, etc...as time allows.
[youtube]RaY-9v-SO_0[/youtube]
Gary, Is there a way for me do download and save the video file? If there is on this forum of youtube, I'm to old to figure it out. Thx, Derek
The following are PCM pin numbers that can be removed if you have no use for their function. Keep in mind not all harnesses will have all of these pins used and take note of any foot notes (like***)before you pull wires. Any PCM wires not in this list MUST be kept!
12- Yellow/White
56- Lt Green/Black
62- Red/Pink
67- Purple/white***
*** On later harnesses where pin 41 is purple, I like to put pin 67 Purple/white in its place. There is another purple wire that we will use so doing so can eliminate the duplicate color and avoid confusion***
Correct.
The reason for it is so that you don't confuse it with the other purple wire (pin 13).
Ok, after thinking about this more, do I swap it on the C115 connector as well and if so, do you know the pin number on the C115? I removed the purple wire completely before I thought about that
Nope. You only need to swap it at the PCM. Then just remember that purple/white is now your A/C or high idle circuit.
EGR:
47- Brown/Pink - +++
63- Orange/ Yellow
65- Brown/Lt Green
On my connector the number 63 pin is blocked out. I dont have a orange/yellow wire. Is there another color in later harnesses? Where does that wire go?
EGR:
63- Orange/ Yellow
65- Brown/Lt Green
My 98 harness didn't have it either but Garry mentioned in post #2 that some of the wires mentioned were not in all harnesses so I'm guessing that's one of them.
When I do this rework, I want to leave the ac in original operation. Do I need to mess with the purple and purple/white wires or leave them alone?
