Explorer OBD2 Harness Re-work
Viperwolf1
electron whisperer
Thanks Gary. I was trying to figure out what I needed to do to get the evap hooked up. I didn't have much luck finding a wiring diagram. I might just swap the pins.
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
It's been a while and my memory stinks, but I thought I put a plug for a purge valve in the rear of your engine harness...?
Viperwolf1
electron whisperer
There is a plug but it doesn't match any purge valve I'm used to. I'd like to use a mustang type valve. uploadfromtaptalk1442882782216.jpg
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
There is a jumper harness that plugs in to what you have pictured and plugs in to the purge solenoid on the other side. You can harvest it from almost any 90's era V8 Ford car or truck.
prosys1
Victorville, CA
I'm going to start you all off with a little video. It covers the very basics of a harness re-work. I'll add a full write up here with pictures covering pin numbers, wire colors, etc...as time allows.
[youtube]RaY-9v-SO_0[/youtube]
Gary, Is there a way for me do download and save the video file? If there is on this forum of youtube, I'm to old to figure it out. Thx, Derek
sykanr0ng
Kind of depends on which web browser you use.
If you use Firefox there is an add-on to download flash and video.
If you use Chrome, Google owns YouTube and blocks downloading from it.
IE?
Safari?
I have no idea.
duffymahoney
You can always just book mark the video and watch it over and over? What was your goal?
Green_Bastard
The following are PCM pin numbers that can be removed if you have no use for their function. Keep in mind not all harnesses will have all of these pins used and take note of any foot notes (like***)before you pull wires. Any PCM wires not in this list MUST be kept!
12- Yellow/White
56- Lt Green/Black
62- Red/Pink
67- Purple/white***
*** On later harnesses where pin 41 is purple, I like to put pin 67 Purple/white in its place. There is another purple wire that we will use so doing so can eliminate the duplicate color and avoid confusion***
Hi Garry,
I'm looking for a little clarification on this part just to make sure I don't mess it up. If I'm understanding this right, I remove the purple/white wire from pin 67 of the PCM plug, and plug it into pin 41, removing the purple wire from it. I'm guessing I also remove the purple wire from pin 41 altogether from the harness. Does this sound right
Thanks again for your help
Jim
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
Correct.
The reason for it is so that you don't confuse it with the other purple wire (pin 13).
Green_Bastard
Correct.
Ok, after thinking about this more, do I swap it on the C115 connector as well and if so, do you know the pin number on the C115? I removed the purple wire completely before I thought about that
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
Nope. You only need to swap it at the PCM. Then just remember that purple/white is now your A/C or high idle circuit.
Green_Bastard
Thanks for all your help again! That's what I initially thought but wanted to make sure. My engine harness is now complete. Any idea when you'll be able to post info on the firewall harness?
jmart52
EGR:
47- Brown/Pink - +++
63- Orange/ Yellow
65- Brown/Lt Green
On my connector the number 63 pin is blocked out. I dont have a orange/yellow wire. Is there another color in later harnesses? Where does that wire go?
Green_Bastard
EGR:
63- Orange/ Yellow
65- Brown/Lt Green
My 98 harness didn't have it either but Garry mentioned in post #2 that some of the wires mentioned were not in all harnesses so I'm guessing that's one of them.
Boss Hugg
Hey, Garry! Just had an explorer engine and harness given to me. Rats have gotten to the harness so it needs a little patching up, but nothing I can't handle. When I do this rework, I want to leave the ac in original operation. Do I need to mess with the purple and purple/white wires or leave them alone?
JoshT
Garry, thanks for making this available to us. Subscribing so I'll remember to check out the next video. Take your time and keep taking care of the family.
mavman427
Nipomo, CA
Wow, great video. Thank you for taking the time to do this, this is a big help!
EFI Guy
EFI Guy
TheEFIguy@gmail
BFE
EGR:
63- Orange/ Yellow
65- Brown/Lt Green
Correct. 2 different types of EGR were used, so you likely only have one or the other.
You don't NEED to, but I would. It just helps to keep from confusing the 2 purple wires.
