englewoodcowboy
Lick Creek Restorations
- Joined
- Jul 25, 2010
- Messages
- 4,200
I just did this mod tonight and have a few things to add. I pulled the pulley adapter off with a 3 jaw puller, it will reinstall with a PS Pump pulley puller/installer tool set available at the parts stores for rent. Doing this allows you to pull the guts out in a complete assembly, no chance of dropping Venus etc. I pulled the rear clip as shown, then tapped on the shaft with a rubber mallet to dislodge the rear cover. Carefully push the shaft through the seal to the rear of the pump and keep everything together. Practice this with the explorer pump first since you will be discarding the guts, all of them... Clean the housing and prep it for the new internals. I did some measuring and there is no need to grind the tabs in the explorer housing. The tabs actually engage the front plate of the pump assembly and the the plates are identical on each pump. The biggest change is the cavity as noted before. Set the new internals on the bench leaving the rear cover plate all together, shaft up. Make a not of the orientation of the slots on the front plate, these need to line up its the tabs inside and slide the housing over the internals pressing it firmly to start the O ring of the plate in the pump. I then lifted the pump and using a dead blow, tapped the cover in to seat everything. Getting the rear clip in is the trickiest part. Once you get it in, be sure to tap the rear cover in one last time so the spring clip fully seats. Use the pulley installer to press the explorer adapter back on. I measured how much of the shaft was sticking through the adapter on the old pump guts and set it back to the same depth. On the relief valve, I swapped only the spring from the super duty pump to the explorer pump. The valve in the pumps are slightly different for the seat so I didn't want to change that. Other than that, it was straight forward. I dumped the explorer guts into the SD housing and took it back to get my core deposit back. Done deal!
