Floor pan cowl lip cut or stay?
Geiri
Iceland
Hi, a quick question. I am contemplating if I should cut this lip off and just let the Floor pan lay flat down for a cleaner look?
What are your thinking's?
Speedrdr
Learning Member
Paris, MS
I’m replacing D/S and P/S floors as well. My plan is to leave the lip. It gives you the strength of the bend at the seam as well as it also allows for more place to weld. At least that’s my plan.
Randy
jeffncs
Raleigh, NC
I welded that side last…. Once the front, rear, outer edge and reinforcement cross-brace was welded, I cut the flange using a cutting disc on my angle grinder. Made for a super clean fit and allowed butt welds to avoid the lap welds.
Geiri
Geiri
Iceland
I have been looking at youtube videos while thinking on this and found this one. It looks as the guy cut the lip of.
Video starting at min: 9:31
Geiri
Geiri
Iceland
Okay, Just a short follow up, for those who might be asking this question later.
I did cut the lip off. The Floor plate now seats properly.
I am not worried about losing strength as it is plenty strong
Speedrdr
Learning Member
Paris, MS
Good to know, @Geiri. This has me seriously contemplating the same thing with mine.
Randy
papy
were you all getting this style floor pan from? i ordered mine from DC and they cam in separate pieces floor/toe and no side lip like the one you cut off.
JP
Geiri
Geiri
Iceland
So I had to grind away more of the outer edge where the lip was to allow for even better seating.
You can see on this photo that the floor plate is not seated correctly there, because the outer edge, where the lip was needs a little grinding.
Seam sealer will cover this all
The next two photos show the spot welding. I like to run my heat very high to make a good floating puddle and burn through, also there is less to grind.
