sneditch
- Jan 23, 2017
- 54
Looking for a sanity check on panel replacement order. Any insights or wtf are you doing is welcome…learning mode for sure.
I have body and frame on a rotisserie and leveled, body mounts replaced, doors and bed braced, everything close to square.
Kick panel not too bad but is rusted where it meets floor pan - A pillar - inner rocker and filled with foam insulation. Inner Rocker and A Plllar are shot so figured why not go further down the rabbit hole since I am there...
Originally thought was to replace floor pans and tunnel first, then inner rocker, kick panel, A pillar.
After seeing this body rotate on the rotisserie I am thinking I should keep cowl braced to frame as it is in pic 8168 below, and instead start by replacing inner rocker, then proceed to kick panel then A pillar etc. Once that slow and tedious process is done then put floor pans, lower f/w, etc.
Any reason not to go this route? Info is appreciated as well as indication of anything I am ovelooking.
Cheers
Sned
Cheers
Sned
