The separated, different looking, oddball hub/rotor is a Ford since it's 5 lug If you had a Chevy hub/rotor, it would be 6 lug as all Chevy's are 6 lug. Certain Dodges have the same 5 lug, 5 on 5.5, but I don't know enough about that to say anything definitive.
Keep in mind, the hub is reuseable if you can press out the wheel studs. The rotor is sold separate at most auto parts stores. So there is no reason to throw away a used up rotor/hub combo. I'd save the hubs if it were my call, even if the rotors are below spec.
