beyer05
First off, I bought this bronco and only drove it home. It drove alright, but was very hard to get into 4th gear (NP435). I pull the tranny and the 3rd-4th gear synchro was broken laying in the bottom of the tranny. Also, the clutch was a little jumpy and jerky. Everything else seemed fine.
- I replaced the 3-4 synchro.
- I replaced the clutch and resurfaced the flywheel.
- I adjusted the clutch to where there is just a little play in the pedal, but the bushings are worn pretty bad on the linkage to the clutch fork. I am going to replace them, but have not yet.
Ok, put it all back together and now when I am driving and push in the clutch, it will roll and then feel like it is grabbing again. I mean to the point that it chirped the tires with the clutch pushed in while I was rolling backwards. Also, sometimes it will get stuck in a gear (while I am at a dead stop or rolling) and I will have to let out the clutch slowly and then it will finally grab and jerk/unload and then I am able to shift out of that gear and into another gear.
I am hoping this is just an issue with the clutch adjustment, but never had anything like this happen. Anyone give me some trouble shooting tips to pinpoint the problem? Thanks.
I a
I a
