- Nov 11, 2007
- 7,840
cam looks nice, you realize thats for a non roller motor, correct? Just checking.
All the tab does is keep oil in the rocker arm as it comes up pushrod, so should be no problem unless one is about to come off. There should be numbers on hear around valve springs that you can find out what they are.
I took the 3 rockers back today (2 bent and cracked, 1 just cracked) and he gave me replacements. These are used rockers and he has buckets of them. The push rods and tappets are new though.
He didn't have a carb valve cover to swap for me. He gave me a thicker gasket and we tapped the baffles with a dead blow hammer to see if that would give enough clearance. If I want, he'll swap me EFI valve covers and even drill a hole for the PCV, but I want to check and see if the current covers will work.
As for the price of the long block, it's in other posts in this thread, but I paid $1,000 plus $200 for a better cam plus taxes.
