Another great video bulletpruf. Thanks for posting.
Just a heads-up at least for the Bronco/half-ton crowd (but probably the same for the HD 44 and Dana 60 crowd). You usually do not need to remove that small Phillips head screw to remove the lockouts.
In fact when using this type of lockout it's easier if you don't. It's only recommended by the factory (Warn in this case) to remove after it's removed from the vehicle, and only when doing a full service of the lockout itself.
The screw is there to retain the inner splined hub, sliding collar and spring within the outer splined aluminum slug, as an assembly.
So if all is working as it should be (no buggered bearings or splines or such) you only need to remove the inner snap-ring (if present) from the end of the axle, and the outer lock ring from the hub, and the entire lockout comes out as a single assembly.
