No I do not plan on replacing but I'll take any recommendations or advice
Dumb question…. Why are you removing it if you arent replacing it? If you need the clearance to pull the engine, buy a gantry or a taller/larger engine hoist. Removing that front support is a big job… I just repaired mine and here’s what’s all tied to it:
radiator
frame mounts
outer fenders
inner fenders
2x body mount brackets (which connect to the wheel well)
3x additional braces (which also connect to the wheel wells)
Spitballing, but you’re probably going to drill 70 spot welds which then have to be broken free, which will likely damage your factory panel.
Then there’s whatever is attached to the support like the horns, igni box, and such.
once the support is removed, the entire front end is a floppy, flimsy wobbly assembly..
