jperry1290
- Jul 1, 2010
- 912
Looking to add auxiliary lights (front and rear leds) to my tow rig. I've scoured several forums, some of which have left me more confused than when I started. Some of the wiring diagrams I've looked at contradict each other. I was thinking of using the Blue Sea fuse blocks to make the install look clean, I want the back up lights to on a 3 way switch (off, on with reverse, or on when truck is parked if needed). Also looking at using lighted toggles.
From what I understand I will have a relay between battery and fuse block then relay between each aux item? I think I can get the fuse block wired with no issues, it just everything past the block.
What is the best ignition power source to tap in to so the toggles won't be lit up when truck is off?
Any diagrams appreciated
