Can you help me confirm something?
I was told recently that I should verify my ignition system and timing is correct by doing the following test.
Check timing at idle, rev the engine up and watch the timing, it should advance as the engine revs up. In my case, not only is the idle timing high 20 degrees, but it drops to 18 then 16 as I rev it up.
I was told this means my reluctor (sp?) is upside down and to reverse the wires coming from the distributor to the MSD box.
Has anyone ever heard of this and can validate this is right?
I have a 351 with a MSD distributor and MSD distributor box.
Appreciate the input.
