hannibal61577
Thanks guys! Workin' on this Bronco has been a lot of fun so far ;D
The hinge was already welded to the cowl when I got it. It appears in great shape, so I didn't bother to replace it. The PO drilled out the spot welds between the hinge and the frame. I just lined up the windshield, clamped it and then welded it back together. I took my time and it went together a lot easier than I expected.
Awesome, I will do that. I was wondering about putting some sealant in there. Thanks for the advice!
Great job on the build, how did you attach the windshield hinge to the cowl? Looks like you welded it to the windshield frame? Thanks and keep up the good work, I like lots of pics!
Looking good, you are doing a nice job. Do yourself a favor and put some sealent, seam sealer or whatever, along with the rubber gasket on the windshield frame or it will leak at some point. I always seal up the outside of the hinge with seam sealer before I paint which stops leaks and prevents rust in the future. Keep up the good wrk youll be driving it before long.
