mduenas
I’ve made so many posts on this and everyone has been so helpful. Long story short I can’t get my truck to stop overheating. I put a 195 FlowKooler thermostat in. I have a rebuilt 302 with a fitech. I also have ac, and power steering.
I put a Ron Davis radiator in, a Hayden 7 blade flex fan in, and taped up my shroud with aluminum tape. As it was hacked to death to accommodate for my 1 inch body lift. I tried to fit the full circle shroud from wild horses and the steel shroud, no go. They both hit my pulleys or my fan was too deep inside the shroud (more of a combination of those 2) my fan sits about 3/4 from my radiator and 1/4” from my crank pulley. I have a new water pump and gauges.
I keep reading about shroud extension straps, but I can’t find any online, and I am having trouble visualizing them. I want to get a new shroud that is intact and see if that helps. My truck stays cold when moving. But once I idle it starts to creep about 1 degree ever 5-10 seconds. I move it drops, and fast.
I am getting enough sucking through the radiator fins to hold cardboard to my grill. But maybe that’s still Not enough. I’m going to pull the thermostat and see if it is stuck closed or staying open. Heater works great and I very diligently burped every bubble out.
In fact when I got all the air out, the truck idled for over an hour and didn’t even get up to operating temperature. Now the last few days, the temps climbs at every stop light. I drive in LA traffic. So I desperately am trying to find a solution. I’m hoping a new shroud. And another thermostat soled this issue.
I have posted this a few times, here my previous threads:
http://classicbroncos.com/forums/showthread.php?t=286069
http://classicbroncos.com/forums/showthread.php?t=286943
http://classicbroncos.com/forums/showthread.php?t=286727
http://classicbroncos.com/forums/showthread.php?t=287090
